Warning message
Bad Voice quality using Exs switch & as5300
I using as5300 connect with my Exs switch, the call is sending from the Exs to my as5300 and terminate by another as5300. However, the voice quality is very bad. I get a noise background sound and echo during making a call. I have upgraded the DSPM vcware to 7.23 and IOS to 12.1.7 for my as5300. Beside, I have fine tune all the voice port for echo-cancel coverage. My Exs switch is using A-law for call sending. I using GB for my cptone. Pls. advise!
p.krane Thu, 03/08/2001 - 13:19
This is something you’ll want to call Cisco on. In order to troubleshoot this you’d need to see your debugs and configs.
chan.m Thu, 03/08/2001 - 17:15
Please check the codec used and try cptone to SG. My PBX also using the A-law and the cptone setting is working fine in my site.
Good luck.
