Warning message
rchester Sun, 03/18/2001 - 12:46
I have not configured this, but you should check that the policys will match, for instance, checkpoint will not support dh group 1, but it is default on IOS, also checkpoint will not support manual key exchange when using ipsec cards etc
http://lists.insecure.org/firewall-wizards/2000/Aug/0078.html
The url refers to a pix, but the software is the same I have been told
Good luck
shave Tue, 03/20/2001 - 07:00
I am currently attempting to get a Pix doing VPN to a Sonicwall Tele2, based on the instructions at the link below. Got it authenticating ok, just seem to be having an acl problem at this point(and it breaks the exisiting mobile client VPN settings).
http://www.sonicwall.com/products/documentation/VPN_documentation.html">http://www.sonicwall.com/products/documentation/VPN_documentation.html
