Warning message
VoIP Call disconnects
Mar 28th, 2001
We are testing VoIp over Satellite link and have configured E & M cards for it.
The voice call disconnects in about 2-3 minutes automatically. Does it have something to do with router configuration or PBX signalling.
Pls suggest.
Amit
r-simpson Wed, 04/04/2001 - 09:13
I think your best bet with this one is to get your debugs and configurations ready and open a case with one of the engineers at Cisco. I’m sure this will require some interactive troubleshooting.
6g.thacker Fri, 04/06/2001 - 08:53
It sounds like you have a hardware detect configuration problem causing the disconnects. This is usually set in class 4 and 5 switches with E&M signaling. This will ensure calls properly disconnect when someone hangs up the phone (reversal ground, I’ think). Typically this is set with a timer to disconnect if caller/switch/PBX doesn’t send the hardware off hook/on hook signal (ground reversal?). Most switches can be set to “detect hardware answer- off”.
amit12 Mon, 04/16/2001 - 05:27
On which hardware should I check for the hardware detect configuration problem.
I haven't really got by what you described as class 4 and 5 switches with e&m signalling.can you please elaborate?
Thanks & Regards
Amit
Markus Schneider Mon, 04/09/2001 - 12:32
  • Cisco Employee,
Make sure the switch is sending back a connect. If we don't get a connect after 3 minutes (if memory serves me correctly) we'll disconnect the call. If you can't find anything, go ahead and open up a TAC case; you'll need 'show ver', 'show run', 'debug voip ccapi' and 'debug vtsp all' OR 'debug vpm all' depending on the platform/version.
