VPN-Client / lost IP-binding on NIC
Apr 12th, 2001
after Installation of the VPN-Client 1.1, the binding of the IP-protocol at the embedded nic is lost. I can bind a new IP-protocol at the nic, but after restart, the binding is again lost. After uninstall of the VPN-Client, the IP-binding at the nic is OK. The IPSec-Tunnel over the Dial-Up-Network works everytime OK. Have you any suggestions ?
Thanks a lot,
Frank
fmeetz Tue, 04/17/2001 - 14:17
  • Bronze, 100 points or more
I had the same problem not that long ago. I had to completely remove the NIC, Setup the VPN client for dial, then reinstall the NIC physically and setup my IP stack for it. Kind of a pain but it worked.
