Warning message
Connection tie-line on MC3810
I have not used this command before and had trouble implementing it recently. I am trying to force digital voice ports on both ends of a link to connect one-for-one but not interested in 'nailing' them up permanently with connection trunk. I placed strings on the voice port and dial-peers for both ends but they failed to make connection. Anyone have anything detailed to read about using this command?
j.lukes Thu, 06/07/2001 - 11:35
You need to insure that you are running correct rev of IOS first here is what we are doing in our 3810's for voice over Frame Relay. The calls are up only when active.
Router Configuration For T-1 Connection To PBX Comments ONLY Not In Actual Configuration
controller T1 0
framing esf
linecode b8zs
channel-group 3 timeslots 22-24 speed 64
mode cas
tdm-group 1 timeslots 1-12 type e&m
loop-detect
controller T1 1
framing esf
clock source internal
linecode b8zs
mode cas
tdm-group 2 timeslots 1-12 type e&m
voice-group 1 timeslots 17-22 type e&m-wink-start
voice-group 23 timeslots 24 type e&m-wink-start
interface Serial0:3
description Frame Port to AT&T
no ip address
encapsulation frame-relay
no ip route-cache
frame-relay traffic-shaping
interface Serial0:3.3 point-to-point
description PVC for Tie-Lines/Data
bandwidth 32
ip address XX.XX.XX.XX 255.255.255.252 XX= IP Address of sub interface
no ip route-cache
frame-relay interface-dlci 38
class FR128-V
vofr cisco
map-class frame-relay FR32-V Map Class For Frame Relay Fragmentation To insure Voice Quality
frame-relay fragment 240 Check Cisco's site or docs for details in referance to Port & PVC size.
frame-relay adaptive-shaping becn
frame-relay cir 32000
frame-relay bc 4000
frame-relay be 0
frame-relay mincir 32000
frame-relay fair-queue
map-class frame-relay FR16-V
frame-relay voice bandwidth 16000
frame-relay fragment 80
no frame-relay adaptive-shaping
frame-relay cir 16000
frame-relay bc 2000
frame-relay be 0
map-class frame-relay FR128-V
frame-relay voice bandwidth 80000
frame-relay cir 128000
frame-relay bc 400
voice-port 1/17
playout-delay maximum 320
playout-delay nominal 160
busyout monitor Serial0:3
timeouts interdigit 3
timeouts call-disconnect 0
connection Tie-line 9012
voice-port 1/18
voice-port 1/19
dial-peer voice 17 pots
destination-pattern 12
port 1/17
dial-peer voice 18 pots
port 1/18
dial-peer voice 19 pots
port 1/19
dial-peer voice 20 pots
port 1/20
dial-peer voice 21 pots
port 1/21
dial-peer voice 22 pots
port 1/22
dial-peer voice 8012 vofr
no vad
destination-pattern 8012T
session target Serial0:3 532
dial-peer voice 9012 vofr
destination-pattern 9012T
session target Serial0:3 38
cross-connect 1 T1 0 1 T1 1 2
end
