thomas.chen Thu, 05/10/2001 - 13:22
  • Silver, 250 points or more
I wouldn’t compare 56 bit and 3DES on performance only. If you need 3DES for security, make sure you get a router that can handle it. The 1700 can handle 3DES 256-byte packets without the VPN module at 300 Kbps and 3400 Kbps with the module. Hope this helps you out.
jcliang Mon, 05/14/2001 - 07:43
Thanks for your input. I guess I did not use a good router example. I should have said a 3640 with encryption card. I believe the 3640 with encryption card is rated at 12 Mbps for 3DES. However, if the customer is satified with single DES, how much more through-put can one expect from the 3640 with encryption card.
royp Tue, 05/15/2001 - 09:53
Actually, for any product using a hardware accelerator, the performance of DES and 3DES are almost identical.
