05-13-2001 11:32 PM - edited 03-12-2019 11:31 AM
I am wondering what the limitations of Voice over IP are in respect to Latency. I am looking at a high latency network (around 400ms RTT) due to utilisation and distance, and I am wondering what kind of effects this is going to have
05-17-2001 06:57 AM
Youll probably get voice echo with that kind of latency. Just my thoughts.
05-17-2001 03:44 PM
You will find that your latency times will be unaccepable for voice traffic. Typically, the "magic number" you want to shoot for is roughly 125mS of latency or better. Although....cisco claims that the last space shuttle that went up used softphone via satellites and it worked fine....I wonder what fine really means?
05-17-2001 04:28 PM
Agree with the above comments that you'll get delay, but don't forget there's numerous queing techniques you can use to prioritise the voice traffic. Might be worth a try to see how much you can squeeze out of the circuit.
