05-16-2001 05:02 AM
I need to know if:
Cisco 11000 Series of Content Services Switch (CSS)
can be used to do load balancing of Firewall Check Point.
I need to Know the new cisco name of "Arrow point Model CS50".
Thank you.
Monica
05-16-2001 08:38 AM
Monica,
Yes, the Cisco CSS 11000 Series can load balance Check Point Firewalls. There are specific design requirements that are layed out in the documentation.
The Arrowpoint Model CS50 is now:
CSS-11051-AC (8 10/100BASE-TX ports)
CSS-11052-AC (8 10/100BASE-TX ports & 1 1000BASE-SX
05-21-2001 06:14 PM
Hi Monica,
Yes, as Gary has indicated the CSS will work with Checkpoint in a firewall load balancing environment. I have just finished a project in which we were using 2 Nokia IP650's and 4 CSS-150's. I used a configuration fairly similar to the one found in:-
http://www.cisco.com/warp/customer/117/fw_load_balancing.html.
There were a few small gotya's but the whole thing worked quite well.
Regards Brett
03-13-2002 09:23 AM
Hi Gary,
We are looking at using 11151 CSS and IP740's.. Can you send me your email if you dont mind..
thanks
07-02-2001 04:50 AM
The CSS is Checkpoint OPSEC certified, and I also believe there is a possibility of creating a Firewall sandwich, one CSS is requried either side.
03-13-2002 01:22 PM
You might also want to check this out:
http://www.cisco.com/univercd/cc/td/doc/product/webscale/css/css_500/advcfggd/firewall.htm
Your FWLB config will vary depending on which method of redundancy you configure with yout CSSes.
Cheers,
Perry.
