Warning message
ISDN BRI NT and VoIP
Jun 4th, 2001
I have a problem with VoIP over ISDN BRI connection in the following configuration:
phoneA--PBXa--routerA======routerB--PBXb-phoneB
Connection between routers and PBXs is made by ISDN BRI using VIC-2BRI-NT/TE in routers.
Ports BRI on routers are configured as NT (network side).
Routers are connected together with leased line (2Mb/s).
When phoneA initiates voice call to phoneB following is happened :
1. routerA transmits VoIP packets to routerB,
2. routerB transmits one SETUP frame (ITU Q.931) to PBXb; after 4 seconds next SETUP
frame
3. PBXb is not responding
4. after few seconds routerA transmits DISCONNECT to PBXa with cause=0x80A2 No circuit/channel available
Transmitted numbers are correct. Layer1 and 2 - correct.
If anybody is interested - I have logs from debug isdn q931 and debug voice ccapi inout.
Thank you for any suggestions.
Przemo
dgoodwin Mon, 06/04/2001 - 07:15
  • Cisco Employee,
The log of debug isdn q931 on routerB would be helpful here. But I am thinking that we need to figure out why when we send a Q.931 SETUP message to the PBXb that it does not respond. Most likely the problem is there.
sarvesh.mishra Wed, 06/06/2001 - 04:34
We would like to know we can enable load balancing & Dial backup between two unequal cost links in 1750 router or not. We are using ISDN BRI and Leased line and a choice of OSPF,IGRP & EIGRP.
lferre Thu, 07/12/2001 - 04:14
could you post the configuration of your router?
