Warning message
ICS 7750 Failover
Jun 8th, 2001
We have a system where there is one ICS 7750 with
VG200 gateways and a Cisco 36xx router as gateways
with three voice T1 termination.
Problem:
Primary SPE failed and the Secondary took over. Then the Primary came back as Seconday. Works as expected.
But all the Dial-Peer statements in the 36xx were pointing to the Primary IP address. So all the DID call which came from Voice Ts busy out. And also in all the VG200s they were pointing to the Primary SPE IP. So we manually change all the IPs in the Dial-peer and in VG200s to the Secondary SPE's IP.
Question:
Is there a way to automatically do this when the Primary fails and the Secondary takes over and vice-versa.
Thank you in advance.
Thaya N
mschlenger Fri, 06/08/2001 - 11:01
You betcha! What you need to do is quite simple. #1 You need to duplicate your dial peer statements #2 Add a preference to the dial peers. See my example and I'm sure it will make more sense.
dial-peer voice 1 pots
destination-pattern 1111
preference 1
port 1/0/0
dial-peer voice 2 pots
preference 2
port 1/0/1
Dial peers work in top down fashion and will keep searching for a match if the 1st one fails!! Good luck.
thayanc Fri, 06/08/2001 - 12:18
Thank you.
I will try that. Have a nice weekend.
Thaya N
