Warning message
Unity Voice Gateway
Jun 11th, 2001
  • Bronze, 100 points or more
I am a Unity Instructor, currently trying to install the Voice Gateway on Exchange and cannot I was told the problem might be with the ldap port on exchange which had to be changes because of Active Directory. Any thoughts on this issue or solutions, we are running Unity and exchange on ldap port 391. Thanks<br><br>
Anonymous (not verified) Mon, 06/11/2001 - 10:30
The version of the gateway install assumes the port is on 389 in all cases and doesn't give you a chance to change it to match what you may have changed it to if you're running on Win2k. This but has been fixed and will be in the next patch release of Unity 2.4.6, however it's not available at the moment.
if you email me directly at my cisco address, I can zip up the gateway from that build and send it to you...
Jeff Lindborg
Unity Product Architect/Answer Monkey
Cisco Systems
[email protected]
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
