XML IP Phone services
Jun 20th, 2001
Do someone knows a website where I can download new services (eg. weather) ??
I also installed the SDK and when I try StockTicker services, nothing appears on the screen... I debugged the program and I found that the problem was this line (around 25):
Inet1 = new ActiveXObject("CiscoURLProxy.URLGrabber")
Nothing happens after.
spodonnell Wed, 06/20/2001 - 19:05
I had the same problem on one install. I found that the CiscoURLProxy.dll didn't register to windows properly when I installed the SDK.
Run "Regsvr32 c:\windows\CiscoURLProxy.dll"
to manually register the dll.
spodonnell Sun, 07/08/2001 - 21:01
Make sure the Cisco dll is registered on the machine.
I think the file is CiscoURLProxy.dll in the system32 directory.
Run Regsvr32 c:\...\CiscoUrlProxy.dll to register
the file with windows.
I had the same problem you are having and this
did the trick.
