Warning message
No port #'s when using ACL?
Is it just me or did the port #’s disappear from the syslog when converting from conduits to access-lists? Those port #’s were invaluable information. I’m currently at version 5.1.2. Can anyone tell me if you get the port #’s back in a higher revision? I’ll probably switch back to conduits if Cisco doesn’t fix this.
rstaaf Sat, 07/14/2001 - 13:28
I am still using conduits myself and am running 6.01 so I can't speak for myself but, I seem to recall others that are using 6.01 have reported that with access lists it still doesn't report ports.
Bob
