06-29-2001 05:44 PM - edited 07-05-2021 11:59 AM
I have tested the ACU utility for the Access Point 340 cisco, works ok with the PCMcia card, the LSM (Link Status Meter) works fine.
I need the same tool for test the link between two aironet Cisco Bridges 340.
Can tell me please if that tool exist?.
thanks for your help
VH
07-05-2001 03:01 PM
Im not aware of any utility for the bridges but you can view the stats from its web interface. Look at chapter 9 in Using the Cisco Aironet 340 Series Wireless Bridges at http://www.cisco.com/univercd/cc/td/doc/product/wireless/aironet/bridge/
07-27-2001 11:06 AM
The AIR-BR342 has the Utility built into the console/telnet interface. In the menus go to diagnostics/linktests/strength. A very nice continuously updating bar graph is displayed. Use an ANSI color terminal emulator for best results.
