Warning message
akerr1527 Fri, 07/27/2001 - 07:53
We use a PCMCIA card that has a barcode scanner wand attached right to it. The product is made by Socket and the model is C-I/O part number is
SL0733-129. This is for a laptop running Windows 9x/NT/2k. Works like a champ! Here is the URL
www.socketcom.com
pwalenta Tue, 07/31/2001 - 12:07
You can also get dirt cheap keyboard plugin based (called PS2 keyboard wedges) from Symbol. If you hunt around you can find them for around $225 or so. Look for the "Spark Scanner".
djkueffner Wed, 08/22/2001 - 04:22
WASP also makes several Bar Code scanners that work. They have a CCD ~$175 and Laser ~$250 that plug into the PS/2 port on a laptop or desktop.
