mmellet Tue, 07/10/2001 - 08:50
Yes, from what I understand the Cisco Aironet access point ships with Web based software tools that can be used to configure and manage the wireless LAN.
jkemery Thu, 07/19/2001 - 10:13
You can also use Cisco Works and suplement that with a WLAN sniffer, Network Assoc. or Wildpackets.
jerryshenk Thu, 08/30/2001 - 14:02
Is there any way to get an AIR-PCM350 into promiscuous mode? And a very related question - what chipset does it use? I think the 340 uses the Prisim2 and the 350 is in the same series and I think the same driver works but it doesn't seem like the Prism utilities work with it.
Trending Topics - Security & Network
