Warning message
Voip over FR drop calls
Jul 12th, 2001
I have 2x2610 with 4xE&M. The voice quality is good, no problem but, a call can be up like 5 minutes and i hear the other side but the other side dont hear me. If there's 3 or 4 calls they last each between 30s and 2m long. Any sugestion? The CO are ALCATEL
smalkeric Mon, 07/23/2001 - 06:47
  • Silver, 250 points or more
This can be tricky to isolate so you might want to debug with Cisco’s tac. I would start by checking that you have QoS set up properly to prioritize your voice packets and fragment other large packets (like file transfers, etc.).
albert.rodriguez Tue, 10/30/2001 - 16:33
Calls dropping after certain lengths of time usaually indicate clocking issues. Take a look at your clock/dce settings and make sure they match.
s.sousa Wed, 10/31/2001 - 02:34
Thanks for the reply.
The curious thing is that when a router goes off power, after the on power the problem maintains for a week. After that it works fine. What i need is to keep both routers on power. But is strange!!
Best regards!
