Warning message
No Sticky
Jul 18th, 2001
In our test enviroment we want our CSS to have no stickiness. We want each page request to bounce around between all the servers. I don't see a way in the CSS to have no stickiness - is there a way? Would making the sticky-mask 0.0.0.0 work? or is there another way?
bradleywong Thu, 07/19/2001 - 07:17
By default, the stickiness is not able in the content rule. However, persistent is turned on based on the flows.
I think that you are looking for "no persistent" in the content rule.
P.S. In the document, it didn't specify the duration of the persistent connection. I guess I will put this question in the board :)
Hope this help.
Brad
sclsjl Thu, 07/19/2001 - 09:36
Hi Brad,
Thanks for your reply. I tried the No Persistent - however I could not get my session to bounce between my two test servers. Here is my test rule - any other ideas?
HTTP
IP Redundancy: Not Redundant
L3: 10.1.124.
L4: TCP/80
Url:
URQL:
EQL:
DQL:
Header Field Group:
Total Bytes: 42221937 Total Frames: 93183
Total Redirects: 0 Total Rejects: 0
Overload Rejects: 0
Balance: Round Robin
Advanced Balance: None
Sticky Mask: 255.255.255.255
Sticky Inactivity timeout: 0 minutes
Sticky No Cookie Found Action: Balance
Sticky Server Down Failover: Balance
ArrowPoint Cookie Path: /
ArrowPoint Cookie Expiration: Browser Exit
ArrowPoint Cookie Text: None
ArrowPoint Cookie Url: None
String Match Criteria:
String Range: 1 - 100
String Prefix: ""
String Eos-Char: "" String Ascii-Conversion: Enabled
String Skip-Len: 0 String Process-Len: 0
String Operation: Match-Service-Cookie
Redirect: ""
Persistence: Enabled
Param-Bypass: Disabled
Services:
Local Load Threshold: 254
PrimarySorryServer: None
SecondSorryServer: None
Name: Hits: Wgt: State: Ld: KAlive: Conn: DNS:
jqa1 1,266 S-1 Alive 2 ICMP 0 0
jqa2 47 S-1 Alive 2 ICMP 0 0
