Hi,<br><br> I'm currently running version 2.4.6 build 102, should I upgrade Unity to build 126 eventhough I don't have any issue right now ? Thank you very much.<br><br>
If you're running on Call Manager I'd reccomend it since the updated TSP (and ones coming down the pike) require 126 to work. If you're not using Call Manager, there's no real pressing need to upgrade from 102 to 126 right away.
