Warning message
ISDN presentation bit on Voice gateway
Jul 27th, 2001
Can anybody tell me how can I set or remove the ISDN presentation bit on Cisco AS5300. The only info I found is that with newer IOS versions it's possible but I don't know how.
Thanks.
thomas.chen Tue, 08/07/2001 - 12:49
  • Silver, 250 points or more
Call Manager “Gateway Configuration” Screen has a drop-down box that allows you to select the presentation bit (enable/disable).
tsvetan.adamov Wed, 08/08/2001 - 23:07
Hi Thomas,
Thanks for your reply but what I wanted were to find out if is it possible to manipulate the ISDN presentation indicator on a Cisco Voice Gateway. For example, not to pass to PSTN the origin number of an incoming call. If you or anybody else knows the answer please help.
Regards.
