Warning message
VPN Client 3.0 to PIX connected through VPN to another PIX
Aug 2nd, 2001
I have sites A and B connected through VPN using PIX Firewalls 515, the first with version 6.0 and second with 5.3. There's full connectivity between both sites. Besides that, the remote users have installed the VPN client 3.0 connecting to the PIX of site A and they have full connectivity to that site. The problem is that the remote users don't connect in any way to site B through the tunnel between both PIX Firewalls.
I'm hoping for some help on this please. Thanks.
murabi Tue, 08/07/2001 - 13:20
Move to 6.0 at site B. I don’t think client 3.0 is supported on previous PIX platforms. If that doesn’t fix it, you’ll want to talk to Cisco to get someone to help you trace your packets and check your routes. Have your configs captured to email your engineer.
