Warning message
Cisco URLProxy
Aug 3rd, 2001
I can't configure these feature to setup IP Phone Services appropriately. Cisco says URLProxy must be installed onto a different server unlike Call Manager, but I have a lot of problems installing this software. Can anyone help me? Thanks.
f.siddi Fri, 08/03/2001 - 08:57
I have already installed the SDK on a IIS 4.0 server....but I think it doesn't work!
pepsiflat Fri, 08/03/2001 - 09:24
tell me exactly what and when it doesn't work!! Any particular service??
f.siddi Sat, 08/04/2001 - 08:09
After installing SDK, I don't know in which way continue URLProxy's setup 'cause I found only a ciscourlproxy.dll file and not an *.exe file... it's wrong or right??
pepsiflat Mon, 08/06/2001 - 08:04
Right!
OK Did you read the development notes ? that's all in the document... but i can summarized it for you..
the parameters of the urlproxy are defined in the XML page. This means that it can be used differently from one page to another...
Look at the StockTicker service that you installed on C:\CiscoIPservices\Services\IIS\StockTicker\ecn.asp ... The dll you talk about is used as an object with properties etc. There's an entire document talking about that specific point. You should read the documents in the folder C:\CiscoIPservices\Documentation .
Hope it helps!
