Warning message
How to access from low security to high security network
Aug 15th, 2001
Does any one know if you can access network from low security level to high security level? Not connecting to one host through specific port in higher security level but able to ping the entire high security level from dmz. I'm using PIX 5.2 version.
Thanks!
jbaigorr Wed, 08/29/2001 - 22:45
Oops! I over looked your primary question. Make sure you don't have a static from the dmz to the entire network on the inside interface and make sure you don't have a conduit icmp any any configured.
