Warning message
PIX 6.0 and VPN client 3.0 support
Aug 15th, 2001
If I am using a PIX VPN solution with release 6.x, will I have to purchase VPN clients for each mobile road warrior or can I download the client for free if I am using the 6.0 release of the PIX software? Also, is there an easy way to administer several remote clients without the use of the 3000 concentrator?
lisa.hall Mon, 08/20/2001 - 14:03
If you bought the VPN license with your PIX, I think you get the client as well. Double-check with your distributor on that. We needed up deploying a 3000 in parallel with our PIX for ease-of-administration and off-loading the work from our firewall.
jsigman Tue, 08/21/2001 - 20:31
Thanks lisa. I did check and it sounds like you can download the client or you can purchase the client on CD for $50.00US
