Warning message
Subscriber weirdness
Aug 23rd, 2001
Although everything is working properly, I noticed that the control center page for my subscriber doesn't show all the services that are running.
I check the windows control panel and can see all
the services are running.
Is there a way to get the web interface straightened out?
mschlenger Fri, 08/24/2001 - 07:58
That sounds strange. I would try rebooting it if its not production. Are you having other problems with the web admin? Or is it just the control panel? I bet a reboot (if you didn't try it already) would fix the problem.
r-reed Mon, 08/27/2001 - 13:20
You might also try restarting the IIS Services.
