Warning message
Increasing Digits for Notification
Aug 31st, 2001
  • Bronze, 100 points or more
I am trying to find a way to input more than 7 digits into a phone number for the Unity system to dial for voice mail notification. Normally I would not want to have the ability to make a long distance call but in this case it won't be. I use the area code of the long distance number to determine which gateway the call will go out so it is not actually a long distance call. How would i incerease this threshold?<br><br>Richmon Schumann MCP/CCNA/CCDA<br>Cox Communications Inc.
Anonymous (not verified) Sat, 09/01/2001 - 08:49
I'm not sure what problem you're running into here... there isn't a 7 digit limit for notification numbers unless you've applied a restriction table limit to them. The Restriction Table of the person changing the delivery number (either via the SA/AA or over the phone) is the limit applied, not the RT of the subscriber who owns the devliery device. As such, as an administrator you should be able to set any notifiction number you want on anyone's notification device you want (assuming your Class of Service is associated with an unrestricted RT).
If that's not what you're talking about, let me know...
Jeff Lindborg
Unity Product Architect/Answer Monkey
Cisco Systems
[email protected]
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
