CM Backup
lterebizh
I tried to configuring backup....
Then run it....
Figured out that it is not start... and cancel it...
Now have constant window "Canceling backup process. Please Wait..."
Reboot system do not help....
Does somebody know what is it?
Thanks in advance...
6 Replies 6
s.jankowski
Level 4
Level 4
I’ve never run into that canceling a backup. You’ll probably need to call Cisco about it but let me know what you discover. What version are you running?
CM 3.1
And what is most intersting... I already reinstall it few time....
And two times tried do backup...One time with local dieactory, other with network ..but mapped as local disk....
I schedule backup... that see that it is not start...
And cancel.... The same picture....
My situation is the same "cancel and never stop" when I left one of my CM off line. This backup utility don't have the "try say three times and skip" built in like others.
In my case, I put back the offline cm online, everything is fine(nothing need to skip).
What do you mean "on-line and off-line"
I have only one CM....
Should I disconnecto from network before start backup? I dont think so....
I figured out how to stop this message on the screen...I goes to regedit and fidout key.... I change it value from 3 to 0 and...It looks like befor start backup....
I still cant see that backup process start....
I tried do backup for local directory... and to network mapped disk.... Not work....
Still struggling...
By the way... When you start backup now...What happening? I mean how it should look like?
I had 3.1 cluster. when any of the cluster memnber off line, my back up and cancell stay at the Staging Cisco CallManager targets (3 on the list) stage. From the log file (Right click the tray and view status) the stucking line was "extracting subscriber information from Ccm0301). when all members online, everything works fine. I did change the regedit Pause to 0 in the begining, but it didn't help my case, unless everything online. My case might be slightly different from yours. It works fine for me for a week now, except won't skip if my subscriber off-line.
when I start backup now, it will go through stage 1 to stage 8 with no problems. with view status, you can see it go through, open stiback.log, local machine name, local ip address, serice account, found --MB availlable, backup with normal priority, staging target, find latest cm database, staging database dump, dumping cdr dat., ...extracting publication from ccm0301, extra.subscriber infor, ....calalog created successfully, all files in staged directory compared successfully.
THanks....
solved....
