Warning message
corporate directory
Sep 4th, 2001
I changed 7960 phone load and restarted cm. Once I did that I lost the corporate directory option from the phones. Now when you hit directory the bottom of the display says "Invalid directory URL" and the only sib menu's under directory are missed, received, & placed calls.
I've tried adding the P003E310 patch, changing back to the "D" load and running the phones from both publisher and subscriber, but can't get the directory back.
Does anyone know what happened?
Rob
dgoodwin Tue, 09/04/2001 - 11:31
  • Cisco Employee,
Go to the Enterprise Parameters. Can you paste in what the Directories URL value is?
dgoodwin Tue, 09/04/2001 - 13:53
  • Cisco Employee,
Sounds like the IIS permissions are wrong.
Go into the Internet Services Manager and check permissions on the CCMUser virtual directory. Everyone should have read access if memory serves.
rvincent Wed, 09/05/2001 - 08:11
Dave:
The CCMUser virtual directory did have read access.
I needed to add "Everyone" to the User folder permissions. This allowed users to get to their user page and see the corporate directory. But everytime I did a directory search I got a XML error (4) display. Once I changed my phone load from the P003E310 to the P003A310, the search started working.
Is there a problem with this "E" load ?
Rob
dgoodwin Wed, 09/05/2001 - 14:40
  • Cisco Employee,
I can't remember a bug off the top of my head but for some reason I am thinking that the E310 load may have a problem with regards to that. I would say go ahead and open a case and see what TAC can tell you.
cajones Thu, 09/13/2001 - 10:11
Same problem here. On the 7960, the P00303010024 load works without problems, the P00303010030 simply doesn't.
