Warning message
Timed access-lists and NTP on C800
Oct 3rd, 2001
Hi !
I was configuring a C800 for DDR when I came to the idea to implement timed access-lists too.
There is a problem due to the nature of the clock in low-end routers that causes the clock to be initialized to some date in the past when powered on. I remember I had seen a configuration sample, (I'm quite sure it was on the German CCO pages), where this problem was solved allowing a one-time dial-up call to reach the NTP server and after that correctly applying the time-based rules to any further call attempt.
I'm no longer able to retrieve this sample or any somilar other, nor more info on the topic.
Maybe somebody has saved the sample or has one on his own to make available ?
mtienghi Fri, 10/05/2001 - 08:40
Ok, I had time enogh to take e closer look at the manuals and endly we got it.
I still wonder if somebody in Germany has kept a copy of the document I mentioned in the previous post. Maybe it was in the support/tricks/C800 section but it's no longer there.
Bye !
