Warning message
OID for DS0 in use on WS-X6608-T1 ?
Oct 5th, 2001
I'm trying to figure out how I can tell how many calls my CallManager 3.0(11) has in progress on a cat 6500.
Is there an OID I can poll to tell me how many calls are active on a WS-X6608-T1 port?
I'm running hybrid IOS, CatOS on the switch and I can only access SNMP via the supervisor engine's IP. Do I need to configure SNMP for each of the 6608's addresses? If so, how?
Thank you for any suggestions.
Kluso Fri, 10/12/2001 - 05:16
Thanks for the response but not exactly what I was looking for.
From our CallManager, we can route outbound calls to an as5300 or a ws-x6608-T1 module in our catalyst switch.
On the 5300 I can use an SNMP tool to get the value of OID 1.3.6.1.4.1.9.10.19.1.1.4. The value of this OID is the number of voice channels currently in use.
On the Catalyst the command SHO PORT VOICE ACTIVE will report the number of calls active in the Total column. I need an OID for the Cat that will return the same information.
