Warning message
CRC errors
Oct 9th, 2001
I T1 coming into a 2501 router through a Adtran DSU. I am seeing a small number of CRC errors (9 errors 3 million input packets). How concerned should I be about this? I have recently replaced both the DSU and the cable running from the DSU to the router and am still seeing a few errors.
lberdick Tue, 10/09/2001 - 13:00
I wouldn't worry too much about it, unless you see a performance or corruption problem.
j.way Tue, 10/09/2001 - 20:26
That's really nothing to worry about at all. However, keep an eye on it to see if there is any true degredation down the line. If possible try testing the connection end to end as well. Again, it's no biggie.
svermill Wed, 10/10/2001 - 09:17
CRC errors are a pretty generic indicator when it comes to a WAN connection. This could be bit errors on the telco connection (nothing to get to excited about) or it could be a result of timing slips (much more serious). Also, 9 errors in 3 million packets over 24 hours is much less serious than the same 9 errors in the same 3 million packets over 24 minutes. I would test the line if you have any test equipment and pay attention to timing as well as errors.
