Warning message
3.0.2 and multiple call managers
Oct 25th, 2001
  • Silver, 250 points or more
  • Community Spotlight Award,
    Best Publication, November 2015
Will Unity 3.0.2 support two or more call managers at the same time? The question is driven by a company with two call managers that are geographically separated, but with lots of WAN bandwidth between the offices. <br><br>
Anonymous (not verified) Thu, 10/25/2001 - 02:36
Two or more CallManagers or two or more CallManager Clusters? The answer for either is yes, but if there are two or more Clusters, CCM will have to be at 3.1.
Steve Olivier
Software Engineer
Cisco Systems
Clifford McGlamry Fri, 01/11/2002 - 01:16
Okay, We have gotten both CCM systems up to 3.12, and Unity is at 3.0.3.
Is there a document somewhere that describes how to configure this (2 separate CCMs...essentially two separate clusters...with a single unity server)?
Markus Schneider Fri, 01/11/2002 - 04:45
  • Cisco Employee,
Not entirely, but it's not that bad. Start with this:
http://www.cisco.com/warp/customer/788/AVVID/unity_bravo.shtml
Then, make sure each callmanager is configured with the same Message Waiting On (and Off) DNs.
For the TSP portion of Unity, you'll simply do steps 10 and on for each callmanager cluster.
You don't want an overlapping dialplan for this either.
