Warning message
errors in a Cisco 7206VXR FastEthernet card
Oct 26th, 2001
Hi everyone.
I send this query because I need some help with a fault that nowadays I have.
I have got a Cisco 7206 VXR with an I/O FE Controller and I can see at the FastEthernet interface a great amount of errors that I not able to know the cause.
You can see an example of statistics below.
FastEthernet0/0 is up, line protocol is up
Hardware is DEC21140A, address is 0003.fecf.a400 (bia 0003.fecf.a400)
Internet address is 192.168.93.195/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 01:33:19
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 314000 bits/sec, 193 packets/sec
5 minute output rate 127000 bits/sec, 241 packets/sec
779995 packets input, 123063628 bytes
Received 8525 broadcasts, 0 runts, 3 giants, 0 throttles
1194 input errors, 1194 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog
607 input packets with dribble condition detected
937826 packets output, 69127848 bytes, 0 underruns
0 lost carrier, 0 no carrier
I opened a TAC a week ago and the engineer asigned to the case sent me a new card. After I had installed the result was same, CRC errors and " dribble condition".
Before opening a TAC I changed the ethernet cable, the port of the switch and even the whole switch. The result was the same too.
In the ATM interface of the router, which is the only card installed, you can't see any CRC error (errors that are due to the physical transmission, I think) neither another kind of error.
You can see some statistics below.
ATM1/0 is up, line protocol is up
Hardware is ENHANCED ATM PA
MTU 4470 bytes, sub MTU 4470, BW 33920 Kbit, DLY 200 usec,
reliability 255/255, txload 2/255, rxload 1/255
Encapsulation ATM, loopback not set
Keepalive not supported
Encapsulation(s): AAL5
4096 maximum active VCs, 7 current VCCs
VC idle disconnect time: 300 seconds
0 carrier transitions
Last clearing of "show interface" counters 02:41:50
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output
Queueing strategy: Per VC Queueing
30 second input rate 73000 bits/sec, 148 packets/sec
30 second output rate 385000 bits/sec, 148 packets/sec
1765814 packets input, 135897012 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 a
1447600 packets output, 238659545 bytes, 0 underruns
I have tried to search in the web what sort of error is "dribble condition detected".
Almost the traffic through the router is Citrix ICA Client (Metaframe).
I've one more question: Could the errors be created by the Metaframe servers that are connected to the same LAN of the router Cisco 7206VXR or maybe by the client in the remote branches?
I look forward to hearing from you.
My best regards,
Albert.
2rsliteris Fri, 10/26/2001 - 03:14
Albert,
One thought. Is the switch the 7206 connected to configured for VLAN's? And if so, is the port connected to the router configured for trunking? One thought was that switches configured with VLANs attach a tag to the header that could cause the packets to be giants. If you are using trunking, be sure to include the command "encap isl " or "encap dot1q " on the fa interface.
Ray
TYLER WEST Fri, 10/26/2001 - 05:20
Agreed. Check your config on the switchport the router interface is connected to. If you still don't see anything, post the config and stats for that switchport and let some of us take a look at it. Two sets of eyes are better than one.
Tyler
icalvo Fri, 10/26/2001 - 06:41
FastEthernet0/23 is up, line protocol is up
Hardware is Fast Ethernet, address is 0004.4d8a.e5d7 (bia 0004.4d8a.e5d7)
Keepalive not set
Auto-duplex (Half), Auto Speed (100), 100BaseTX/FX
Last input 1d17h, output 00:00:36, output hang never
5 minute input rate 7000 bits/sec, 11 packets/sec
5 minute output rate 10000 bits/sec, 12 packets/sec
63423387 packets input, 923823130 bytes
Received 396 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 265 ignored
0 watchdog, 8 multicast
55395518 packets output, 1262243013 bytes, 0 underruns
82350 output errors, 39119 collisions, 1 interface resets
0 babbles, 82350 late collision, 50285 deferred
Last clearing of "show interface" counters 1d04h
5 minute input rate 88000 bits/sec, 64 packets/sec
5 minute output rate 40000 bits/sec, 87 packets/sec
7279620 packets input, 1294973341 bytes
Received 82038 broadcasts, 0 runts, 6 giants, 0 throttles
11601 input errors, 11601 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog
5839 input packets with dribble condition detected
8616514 packets output, 666367320 bytes, 0 underruns
interface FastEthernet0/0
ip address 192.168.93.195 255.255.255.0
no ip proxy-arp
full-duplex
no cdp enable
interface FastEthernet0/23
interface VLAN1
ip address 192.168.93.220 255.255.255.0
no ip directed-broadcast
no ip route-cache
KONSTANTIN FEDOROV Fri, 10/26/2001 - 07:59
Hello
Oh ... :)) In my previous answers I did not think about this.
Change duplex on the FastEthernet0/0 to full, It will be help.
MickPhelps Sat, 10/27/2001 - 09:15
FastE0/0 is already full
FastE0/23 is half
Look at E0/23
Late collision on half-duplex and CRCs on full duplex are indicative of duplex-mismatch.
Verify that FastE0/23 is set to full.
Mick.
icalvo Mon, 10/29/2001 - 04:16
hi,
you're rigth. It seems to be the real problem.
Thank you.
KONSTANTIN FEDOROV Fri, 10/26/2001 - 04:33
Hello
Hm.. I know some problem with 2FE I/O controller, this problem concern
different partical size FE's and others interfaces.
You have faced with not trivial problem, I think only protocol analyzer can help you.
Well I will think about this
2rsliteris Fri, 10/26/2001 - 04:42
A dribble condition occurs when the router detects a packet that is slightly larger than specification allows. The router will forward the packet and increment the dribble condition counter.
