Warning message
vpnclient - pix - 3000concentrator
Oct 26th, 2001
After upgrading the pix to ver 6.0(1) the ciscoclient cannot establish the tunnel to the concentrator. The concentrators public i/f was then moved from the dmz to the pix's outside i/f, this action made the clients work again.
Any clue why it doesn't work on the dmz ???
r-simpson Thu, 11/01/2001 - 06:52
Compare your before and after configurations. It sounds like something changed after the upgrade.
Fredric Nilsson Thu, 11/01/2001 - 11:34
Hi!
Can you describe how your networktopology is now and before?
Fredric
mamarcus Tue, 11/06/2001 - 23:04
Hi.
The networktopology is not changed at all, only the
pix software was upgraded from 5.x to 6.0(1).
The vpn concentrators version is 3.0.3.A
Mats
joels Fri, 11/02/2001 - 08:08
What version is your concentrator ? Can you try the VPN Group in the concentrator with IPSec thru NAT turned on ?
