Warning message
How Do I Change WCCP Router Identifier?
Peter Marchand Wed, 10/31/2001 - 13:10
  • Cisco Employee,
The router ID should not have any effect. The router ID in WCCP should be the highest IP on the router interface or Loopback address. If you do not like the router ID you can create a loopback address that is higher than the current router ID and change it.
