Warning message
First wireless Project
Oct 29th, 2001
Other than the standard CISCO AP , NIC and RADIUS server,is there any recommended product (hware or sware) I should be looking at before attempting to put a basic wireless LAN together...First time attempt
jhelm Tue, 10/30/2001 - 14:16
One aspect you may consider that is not hardware nor software however equally as important as the correct choices each is having a proper site survey and installation done to design the network based on your needs. If you are simply trying to test wireless in a small area for curiosity sake then this is not needed however if you are going to implement this in a large environment then it is an absolute requirement for proper functionality. For more information go to www.netcomitl.com
Trending Topics - Security & Network
