Warning message
Enu_Enu_UninstallDefaultDatabase.dcs?
Oct 30th, 2001
  • Bronze, 100 points or more
What senarios would cause us to need or want to run the ENU_ENU_UninstallDefaultDatabase.dcs (with ConfigMgr.exe)with build 2.4.6.135? <br><br>
Anonymous (not verified) Tue, 10/30/2001 - 09:56
you probably wouldn't... if you were going to run that (which removes most of the Unity stuff from the directory) it would mean you're uninstalling Unity and you'd be much better off running the Uninstall application to get everything off and prep for a clean reinstall.
Frankly I'm not even sure why that DCS script still ships... it used to be used with the now-departed "reinstall" option offered by the Unity setup.
Jeff Lindborg
Unity Product Architect/Answer Monkey
Cisco Systems
[email protected]
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
