Warning message
ISDN testing
Oct 30th, 2001
How will i force/test the ISDN link to dial to ensure good link/configuration on both routers.
The ISDN was used in the event that primary link is DOWN.
Configurations.
Router A
interface BRI0/1
description Backup for Deonar, Mahim and Higi - 3801350
ip unnumbered Loopback0
encapsulation ppp
no ip route-cache
no ip mroute-cache
logging event subif-link-status
dialer idle-timeout 100
dialer map ip 182.192.2.50 name CONINHI1
dialer map ip 182.192.2.58 name CONINNR1
dialer map ip 10.198.124.50 name CONINMH1
dialer hold-queue 10
dialer-group 1
no fair-queue
ppp authentication chap
ppp multilink
hold-queue 75 in
Router CONINNR1
interface BRI0/0
no ip address
encapsulation ppp
dialer rotary-group 0
isdn switch-type basic-net3
priority-group 1
interface Dialer0
ip address 182.192.2.58 255.255.255.252
encapsulation ppp
no ip route-cache
no ip mroute-cache
delay 210000
dialer in-band
dialer string 3801350
dialer-group 1
priority-group 1
bridge-group 1
ali-franks Wed, 10/31/2001 - 02:00
Hi Oliver,
I guess that 3801350 is the number dialed to reach the other router? Bit confusing as you have the number in the description of the first router and also as a dialer string on CONINN. If so use,
isdn call interface BRI 0/1 (dialer string)
This will force B0/1 to dial the far end.
To disconnect the call:
isdn disconnect interface B0/1 all
Also, on Router CONINNR1, you need to have the "dialer pool-member (number)" command under BRI0/0 and the "dialer pool (number)" command under D0 if this interface is to place calls. This will associate the BRI port with the correct Dialer interface.
Hope this is of some use.
Ali
svermill Wed, 10/31/2001 - 07:32
Don't know what you have defined as interesting traffic but if it is something like "ip any any" you can just ping the distant end to generate interesting traffic. Of course, you have to logically shut the primary interface that is being backed up or pull the cable.
okenobi Thu, 11/01/2001 - 11:13
dont forget to remove the backup interface command from your backedup interface, or it will not dial.
