Warning message
upgrade path - Unix Dir to CSPM
Oct 31st, 2001
I am currently running Unix Dir on HPUX OV. I see that HP OV 6.2 will not be supported for Unix Dir, and HPUX will not be supported in newer versions of IDS. I should be able to switch to CSPM on W2K for free shouldn't I then? Is there a special upgrade/switch part # to move from Unix Dir to CSPM? Cisco, don't leave me high and dry here.
thomas.chen Tue, 11/06/2001 - 12:53
  • Silver, 250 points or more
Have you checked with your Cisco rep? I’m sure they’ll take care of you.
