QOS using video over IP
Nov 1st, 2001
We are using Polycom video systems on our company and
I was assign to do it over the private IP backbone which consist of fractional T's to Europe. The first router hop bw is 1024 M and the second one is 1920K.
I am presently using Low latency queueing which prioritized 768K of traffic over the serial connections. No other special configuration in configured on the routers except this Class Based WFQ
with priority :
sh policy
Policy Map wan
Class video
Weighted Fair Queueing
Strict Priority
Bandwidth 768 (kbps) Burst 19200 (Bytes)
Anybody out there who can help me with the configuration because even when the network is not congested, there are some glitches on the video and sometimes frozen. appreciate any help extended to me on this.Here is my config on each the 3 router:
class-map video
match access-group 101
policy-map wan
class video
priority 768
access-list 101 permit ip any any precedence critical
int ser 1/0/X
service-policy output wan
EJ
GOD BLESS AMERICA!!!
dgoodwin Sun, 11/04/2001 - 19:18
  • Cisco Employee,
It may be that you don't want to allow anything with precedence critical. Unless you have a policy implemented somewhere which sets everything but video to something other than IP precedence 5 then you could be giving a strict priority to non-video packets.
It may be a good idea to make the access-list somehow more selective, for instance adding IP address ranges, protocols (UDP), and/or port numbers for the video traffic.
Also, do you have kind of admission control mechanism in place to make sure that the total traffic used for videoconferencing does not exceed the 768k size?
