Warning message
How many calls 3661 Voice gateway can handle? help
Nov 9th, 2001
hi,
i have 3661 with E&M connecting the PBX,
if my PBX Supports 120 phones, it means the 3661
can handle 120 calls concurrently?
if i used 3661 with 6 NM-2V (12 VIC-2FXS),it can
handle 24 calls concurrently?
if i used AS5300 WITH 4E1(can support 120 calls ),connect to the PBX,if the PBX supports 200 calls, does it mean the AS5300 support 200 calls concurrently?
thank you
dlewis1 Sun, 11/11/2001 - 16:34
The gateway can support the number of possible voice channels, not necessarily the number of phones on the PBX. With 6 NM-2V, you can support 24 calls (since that is 4 calls/ports per NM-2V). The NM-2V will support E&M or FXS or FXO. With Digital ports on the 3661, you can support many more calls simultaneous since each T1/E1 will support 24/30 calls.
With the AS5300 you have 4 E1. This means 4X30 = 120 calls. If PBX supports 200 calls, you still are limited by the number of voice channels you can connect to the AS5300 which is 120.
w.zhanghua Sun, 11/11/2001 - 19:14
what's the Digital ports on the 3661, for example:
with 3661 i have NM-HDV-1E1-60=, the diagram i supposed is below:
(60)ip phone ----switch----3661(NM-HDV-1E1-60=)---WAN
or
60 phone---PBX---3661(NM-HDV-1E1-60=)----WAN,
which one is correct?
if the last one is correct, which cable for 3661 connecting PBX,
THANK YOU IN ADVANCE
