Warning message
gateway router
Nov 14th, 2001
hi every one
i need a help on how to use tow gate ways on one network .
i have tow isp connection every one of them have its own gateway ... so the internal users can use one of the gateway..to start connection to internet by using static tcp/ip configuration ...
my question is : is there any way to use both gateway without the needs to make manual tcp/ip configuration for the internal users any ideas on the gateway routers i have 7200 and 2500 as gateway routers ...
best regards to every one
jc.reynes Thu, 11/15/2001 - 10:02
According with your internet providers, you can make BGP routing. Ask to your provider for this.
Regards.
msim68 Thu, 11/15/2001 - 15:05
thanks for answering and i will try that
