Warning message
What's wrong here ? Take a look PLEASE
Hi all,
I have an Cisco ISDN 801 which calls up fine to the internet when i go in my browser but i don't get any data from the internet. IE says page not found. The usual error when you don't have connection. I hope somebody can tell me what's wrong in my configuration. My host does have the gateway ip from the router so that shouldn't be a problem.
Any suggestions are more than welcome. I've used alot of nights trying to figure what's wrong.
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Cisco801
enable password 7 05060F072045
ip subnet-zero
ip dhcp pool 1
network 192.168.0.0 255.255.255.0
default-router 192.168.0.2
dns-server 10.116.231.152 10.116.231.123
no ip domain-lookup
isdn switch-type basic-net3
process-max-time 200
interface Ethernet0
description connected to EthernetLAN
ip address 192.168.0.2 255.255.255.0
no ip directed-broadcast
ip nat inside
interface BRI0
description connected to Internet
no ip address
ip nat outside
encapsulation ppp
dialer rotary-group 1
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
no ip split-horizon
dialer in-band
dialer string 80900550
dialer hold-queue 10
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname BK045D1\gmarinescu
ppp chap password 7 020B014908030B245F18
router rip
version 2
passive-interface Dialer1
network 192.168.0.0
no auto-summary
ip nat inside source list 100 interface Dialer1 overload
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
dialer-list 1 protocol ip permit
snmp-server engineID local 00000009020000B0C28912B7
line con 0
exec-timeout 0 0
password 7 141A1B030D0D
login
transport input none
stopbits 1
line vty 0 4
exec-timeout 0 0
password 7 00091A0E0552
login
end
MickPhelps Sat, 11/17/2001 - 15:34
I would change:
to:
ip nat inside source list 1 interface Dialer1 overload
and add:
access-list 1 permit 192.168.0.0 0.0.255.255
Mick.
Wow Thanks alot. It now works perfectly. I don't even know how to thank you. You've just saved me couple of weeks on figuring out what's wrong.
Another thing is. Do you know how i activate the second ISDN line so the router always will call with to lines ? Anyway this is just an extra thing i ask for. I think i can figure it out but since i see you have alot experience with cisco routers it should be easy for you to answer. That will save me some reading.
Thanks alot again.
Best Regards
Mihai Marinescu
Denmark
MickPhelps Sat, 11/17/2001 - 17:02
I don't want to give you *all* the answers! ;)
Check out "ppp multilink"
Mick.
cybrgenx Sun, 11/18/2001 - 13:51
also check out "dialer load-threshold"
and change your password... even though your config displays it in an encrypted form it is still way to easy to crack... some hints on what not to make you password ... 1, 5 or less digits 2, none alfa-num 3, a "name".
