2950 configuration issues VLANs and Trunking
Nov 19th, 2001
Can anyone assist, We have purchased a number of 2950's and cannot get them to talk to anything other than another switch, even in default config they will not uplink to a Nokia firewall or other none switched devices --- can anyone help or advise if there is a better replacement for the 2924 which did multi VLANs to other equipment
millerv Tue, 11/20/2001 - 10:39
Have you tried to manually set the port speed and
duplex settings ?
Sometimes (the Pix for instance) the devices do not
perform auto negotiation correctly.
Try that first.
