Warning message
Dial Up connection PRI to BRI and BRI to PRI (Both Way)
Nov 19th, 2001
Hi All,
I will appreciate if someone can share his experiences about the dialup connection. I have E1/PRI in central site and BRI's in remote sites.. Both site, central and remote, can dial and accept dial from central or remote site. So it's not like a "legacy dial up central to remote site".. If it's possible, can you give the sample config or the url in the cisco web site...
many thanks
regards
wongsusanto Wed, 11/21/2001 - 00:09
hi there,
many thanks to you
I try, I will let you knwo the result....
regards
