TX Gain (output gain) on the 803 ISDN Router
mark.vosper
Is it possible to change the TX Gain setting on my 803 ISDN Router? The IOS version is 12.1(3)XG.
lisa.hall
Level 2
Level 2
I don’t see any adjustments. What is the problem you’re trying to resolve?
Hi, Thanks for the reply. I'm having problems with the POTS port. When making a call I can hear my own voice, like an 'echo'. It seems the volumn is high, as the the persons voice on the other end of the line is very loud. I thought by reducing the TX Gain, this might solve the problem?
Also, the router does not detect a 'hang up' when someone has left a message on the connected answer-
machine. Any ideas?
