Warning message
PIX and lan connections dropping
jwitherell Thu, 11/29/2001 - 15:09
Can they access anything else on that subnet without any problems, or another subnet on the internal network? You're saying that *everything* else works, except going through the PIX, right?
I assume the "local segment" means that IP network, instead of the entire internal network, right?
I'd look at your DHCP server. Perhaps also your routing tables for the router(s) servicing that area to make sure you're getting a good last resort route on all involved routers.
brford Thu, 11/29/2001 - 16:48
  • Cisco Employee,
Ben,
Are you using the DHCP server in the PIX?
Do you have your own DNS inside of the PIX or are users PCs configured to use a DNS outside the PIX?
Liberty for All,
Brian
We are not using internal dns, and dhcp is provided by a microsoft server. After a period of time the pc's are unable to get to the internet. They can't even ping outside the local network. they can get the internal interface of the pix but no further. running winipcfg and releasing the ip address allows them to get to internet again.
