Warning message
Need HELP - Linux VPN Client not connecting to PIX
Nov 29th, 2001
am having this problem.
I have a Dell Laptop running Red Hat 7.2
VPN Client 3.0.8
connecting to a PIX525 with 6.0.1.
I run the client and get the following:
Initializing the IPSec link.
Contacting the security gateway at xxx.xxx.xxx.xxx.xxx
Negotiating security policies.
Failed to contact the security gateway.
Now I know the last entry is incorrect, because when I look at the log I see that the pix has passed to the
laptop an ip, domain name, dns ip address, etc.
It then receives the following error:
Error -1 obtaining host interfaces on the system while creating dynamic ACL entries
Failed to enumerate interfaces on the system
and finally:
API Failure - Function call IPSecDriverInitialize returned 1.
I know that everything else works because I can make the same connection with my Windows 2000 box and
it works.
Any assistance would be greatly appreciated.
cjacinto Sat, 12/01/2001 - 19:47
  • Cisco Employee,
Check the following:
Make sure you are using the latest 3.5 client.
* You must run "/etc/rc.d/init.d/vpnclient_init start" before using the client
* This script will be run AUTOMATICALLY every time you reboot your computer.
Firewalls installed on a Linux box such as IpTables, Ipchaining.
You need to make sure that the following are allowed to pass through:
UDP port 500
UDP port 10,000 or whaterver port you are needing for Ipsec thru Nat functionality
IP protocol 50 (ESP)
Tip to check that Ipchains is setup on the Linux Box:
more /etc/sysconfig/ipchains
Look for
-A input -p udp -s 0/0 -d 0/0/ 0:1023 -j REJECT
To make sure that UDP traffic is allowed through DELETE THESE lines and Stop Ipchaining and Restart with your changes:
/etc/init.d/ipchains stop
/etc/ini.d/ipchains start
