Warning message
SRST - fast busy on outbound after 1 digit
Nov 29th, 2001
CM 3.1(2c), SRST on 2620 with PRI. I followed all the sample configs. Inbound calls work fine. When I try to make an outbound call, I get fast busy after the first digit(no matter what I dial).
Here is config:
dial-peer voice 1 pots
incoming called-number .
destination-pattern 9.
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 1/0:23
call-manager-fallback
ip source-address 10.7.199.3 port 2000
max-ephones 24
max-dn 48
dialplan-pattern 1 630754.... extension-length 4
default-destination 3204
voicemail 5000
Thanks in advance.
ehaseki Thu, 11/29/2001 - 22:57
In the Dial-peer pots configuration you should write "destination-pattern 9T" instead of "destination-pattern 9.". Hope it helps.
ERDEM...
v.kangin Fri, 11/30/2001 - 01:01
or try this:
with no dot. you only want the 9 to get the line for you.
tvanblon Fri, 11/30/2001 - 12:33
You must be running IOS 12.1(5YD) code, which does not support PRI with SRST. Upgrade to 12.2.2(XB).
