Warning message
How can I use csutil import tool to add more attributes to users?
Dec 3rd, 2001
I can use csutil to add users. for example, the import text file have the following content,
ADD:user01:CSDB:userpassword:PROFILE:1
However, I want to permit single login / assigning IP to this user. How can I edit the import text to do so? Is there any reference material about using csutil in more details? The user guide only teach me to assign user name/password/group only.
Thanks!
r-simpson Mon, 12/10/2001 - 06:41
You’ll have to use csutil to import an ODBC database that contains the specific attributes. Import definitions can be found at http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/csnt24/csnt24ug/ch4.htm#xtocid940433
The execute csutil -i filename.txt to import all of the database definitions. You might start by using csutil –d to create a dump.txt file of your existing database, then edit that with your new user info and attributes and then importing it back in.
